KD55-XE8577 HDR10+
thedozyone
KD55-XE8577 HDR10+
Hi
Does anyone know if the KD55-XE8577 is likely to get a HDR10+ update?
I wasn't sure if this was a hardware limitation or if it was purely software.
Thanks in advance !
Sean_Mc
Moderator
Hi thedozyone,
I can't confirm this, but it would be best to enable automatic software downloads on your TV so that you would receive any future updates from Sony.
To enable [Automatic software download], press the HOME button, then select [Help] — [System software update] — [Automatic software download].
Thanks,
Sean Mc
thedozyone
Thanks for the reply Sean my TV is already set to automatics updates.
My question was really if the feature might be added in the future or if the hardware isn't capable of decoding HDR10+
