Xe80 IR sensor location
Fzrkev77
Hi folks,
As above says, where is this little bugger hiding? I know it's on the bottom somewhere, but can't pinpoint it. Need to find it as I'm in need of an IR repeater to help negate the blocking of the signal by my sound bar.
Sean_Mc
Moderator
Hi Fzrkev77,
I'm not entirely sure where it's located, as you say it's somewhere on the front.
You could check if there's any sign of a light when you press a button on the remote.
Thanks,
Sean Mc
