KD55A8 recording to hard disc
skeith
I cannot record to a Seagate expansion 1 tb external hard drive via the usb hdd port.I have followed the set up instructions and the test says everything is ok, When I press the record button a message tells me that recording is unavailable,despite the manual saying that it is.
Any ideas anyone.
rooobb
You don't have youview enabled, don't you?
rooobb
Joe_Dohn
Specialist
@skeith has this solved your issue or have you managed to solve it another way?
