Kodi Thumbanils
lollypop11
Kodi Thumbanils
 Hi, I wonder if someone can help me please because I have reached to the point where i am picking my hair out.
I have a Sony tv XE9005 with Kodi (17.1) installed from the Google Play Store. I have added movies using smb share from my external nas. I can see thumbnails for on main deck for recently added and in progress movies however, when I go to videos, all i see is blank folders, no thumbnails. I have scanned the library using all different scrappers, deleted/reinstalled kodi to an older version/ changed the shares from smb to nfs but still I am unable to generate thumbnails in videos.
I have also tried adding a folder as a favorite but cannot see thumbnails for that either.
I have added the same movies collection on my windows 10 pc using smb shares, all thumbnails show fine. Its just that kodi on Sony tv does not show the thumbnails properly.
Is there some sort of issue with Android software on sony tv that does not allow caching of thumbnails properly or something is not right?
See the screenshots
Any help please?
10 REPLIES 10
lollypop11
Anyone?
profile.country.HR.title
kinggo01
you should really use "movies" category and not "videos".
lollypop11
I agree but movies show all my videos together and does not sort out movies according to animation/documentaries etc.
secondly what could be wrong with showing no thumbnails for folders added through the shares? Since these shares work fine on my other devices.
Hi there
I can only really point you to the Kodi forums on this im afraid. Although I note that you already have posted their too: http://forum.kodi.tv/showthread.php?tid=314109
lollypop11
Yes. I am 100% sure it is something do with Andoid installed on Sony not giving correct permeasions to smb shares to cache the thumbnails.
lets see if some genius can figure out.
cheers
kinggo01
there's nothing wrong. It's just that kodi doesn't show thumbnails in filemanager mode which is what you are using in first picture.
What you can do is, add some tags in "movies" view and than add yours accordingly.
lollypop11
This is not file manager mode; it is in "videos" section.
kinggo01
sure. But your view in the first picture is under "files".
lollypop11
Yes it is. I go to videos, files and then english folder which has all the movies sorted in thier own folders.
But the thing is my other system such as windows pc is showing thumbnails in movies section and in videos section. so does mrmc on apple tv 4 which is a forked verion of kodi.
I could be wrong but i am sure it is something to do with permessions or write access to andoid system on sony tv. I just read this thread where people are complaining about the similar writing permessions:
https://community.sony.co.uk/t5/android-tv/writing-on-usb-disks-impossible-on-marshmallow/td-p/22975...
