[Master Thread] - Marshmallow Update - Amber/Green Blinking LEDs
HUSH2H
I believe this issue deserves a separate thread since it is affecting so many people around Europe. After Sony released the update i put it on a SONY stick and proceed to upgrade, the tv was reporting: 'updating' then it restarted but it did not come back - black screen and led flashing green-orange! Tried all the tricks to get it to work but no luck so far
Lots of people complain abotu this issue on a russian forum: 'Killed sony kdl43w808c, Slovakia, 11/2016. I called Sony support. Told not to turn off the TV set or disconnect it from the Internet, as update should come, correcting this problem'
https://translate.google.com/translate?sl=auto&tl=en&js=y&prev=_t&hl=en&ie=UTF-8
426 REPLIES 426
vick18
i tried to navigate blind from the black screen. it doesnt make sense the beeps i go through... 😞
Kadlinko
The same problem here.
bazsoz
Hy all.The same problem as all of you.After update,screen blank,amber/green blinkin. KDL43W755c I'am from Hungary.
vick18
has anybody tried to reboot the tv by android console so far?
vacalimar
how to reboot tv? i have the same issue (serbia)...
Droncs46
The same problem here. Russia
43W755C 08/2016 Production Slovakia
Tomi2004A
Me too,from Hungary Amber/Green blinking have sound no picture
Kdl 43w807c
vacalimar
c'mon sony, my ps 4 is crying!
HUSH2H
it does not work if you did not set your tv to developer mode before updating
already tried, installed Android Studio then from windows CMD used: adb connect TVIP
C:\Users\MYUSER\AppData\Local\Android\sdk\platform-tools>adb connect 192.168.1.5 unable to connect to 192.168.1.5:5555: cannot connect to 192.168.1.5:5555: No connection could be made because the target machine actively refused it. (10061)
vacalimar
thanks hush!
