Netflix error -12
profile.country.IE.title
Bobbyj
Netflix error -12
Netflix on my kd-55xe8396 has stopped working. I can even sign in. I tried a factory reset but the same error is still coming up.
I can login to Netflix on my phone and play perfectly but if I cast to the tv I get the same error
Amazon prime, you tube and google play all work fine though. Anyone any advise?
Mick_D
Moderator
Hi @Bobbyj
Have you tried restarting your router? Worth a try...
Mick
