Pop Up Side Banner
profile.country.GR.title
manostsoukalas
Pop Up Side Banner
I have these popup side bars keep appearing and i dont know how to remove them. My model is KDL-37S5600. Thanks!!!
Pascale_F
Moderator
Hi manostsoukalas,
Welcome to the community.
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
Win_88
Specialist
Hi manostsoukalas,
I'd try try going through the initial set up using the Auto Start up option (found on page 24 of the manual) and make sure you select Home as opposed to Shop.
Win_88
