Sony AF8 Remap TV Button
georgie1312
For some reason on my Sony AF8 tv, I can’t remap the TV button on the remote. I’ve read a few forums which all say that the option is under Settings > External Input > Customise TV Key but the option ‘Customise TV Key’ isn’t there. It used to work as I wanted it to before but all of a sudden the TV button started playing Google Play trailers when it was pressed which is really annoying. I don’t have YouView set up either.
EdwinaU
Moderator
Hi Georgie,
Can you please try the troubleshooting tips here for your remote control. Let us know if this helps.
Best wishes,
Ed
georgie1312
I followed the instructions but no luck. I think the problem is more to do with the setting being missing in the tv settings rather than anything to do with the remote itself.
