Problem using Alexa to control my XE9005
jimandjane116
I have set up Alexa to control this TV but there are issues.
I can turn the TV on and off without a problem.
If I ask to switch to Netflix or Amazon Prime this also seems to work constantly. If I then ask to switch back to TV then the Alexa message says it is doing that but nothing happens. If I am on TV I can control the volume ok but, when I ask to switch channels, I get a message confirming it is being done but again nothing happens.
Does anyone else have similar issues?
5 REPLIES 5
Joe_Dohn
Specialist
When you say "TV" do you mean to say channels on the TV itself using an aerial or is it an external device (set-top box like a Humax, Virgin, BT, etc..)?
Controlling the channels should be supported, but I'm not sure if it would work on a box.
Hope this helps!
- JD
jimandjane116
It is directly on the TV. The TV turns on ok but Alexa will not change the channel or alter the volume level although it acknowledges the request and says that it is doing it. I do have another issue in that it will switch to Netflix or Prime Video on request but I can't do anything further are I use a Harmony 650 remote which I don't think is supported by Sony.
Joe_Dohn
Specialist
Have you tried the basics of disconnecting everything and unplugging for a few minutes and such?
jimandjane116
Thanks for this. I tried everything but in the end I have decided not to
continue trying with this.
Thanks for your help though.
Joe_Dohn
Specialist
Sorry to hear that, but if you do change your mind, people around the forum are always helpful ^^
