Reparare LCD TV Sony KD65XF9005 in afara garantiei
profile.country.RO.title
TiberiuH
Buna ziua,
Tocmai am aflat ca Sony nu repara LCD-uri defecte (banda neagra verticala care s-a extins la aproape 3 cm)  in afara garantiei, motiv pentru care a propus sa-mi cumpar un televizor nou. Pret televizor vechi 6500 lei in 2018. Pret televizor nou 5991 lei. A functionat 30 de luni.  Daca cel  nou va functiona tot atat?
***** vi se pare aceasta abordare si ***** vi se pare ca varful de gama de la Sony in 2018 sa reziste 30 de luni  (sub 10000 ore de functionare) , cand Sony in reclamele sale spune ca regimul de functionare heavy duty este de 4 ani minimum sau 40000 de ore de functionare  iar durata de viata conform garantiei este de 3 ani
***** vi se pare sa nu existe nici o posibilitate de reparare in afara garantiei? Adica arunc pe geam peste 6000 de lei.
As fi recunoscator pentru orice sugestie despre ***** as putea rezolva. Pentru moment am depus o reclamatie la protectia consumatorului.
Va multumesc,
7 REPLIES 7
TiberiuH
Also in english:
The LCD of my Sony TV model KD65XF9005 become defective (black 2 cm vertical line) after 30 months since I purchased.. TV is out of warranty. Sony proposed me to buy a new one almost on same price (around 1400 EUR). They stated their policy is to not repair LCD but to change the device.
What do you think about this approach
Is it normal that  that the top of the range from Sony in 2018 to last 30 months (less than 10,000 operating hours), when Sony in its ads says that the heavy duty operation is 4 years minimum or 40,000 operating hours and the lifetime according to the warranty is 3 years
Do you think there is no possibility of repair outside the warranty? I mean, I'm throwing over 6,000 lei on the window.
I would be grateful for any suggestions about how I could solve this issue. For the moment, I have filed a complaint with the consumer protection.
Joe_Dohn
Specialist
Unfortunately, the display panel is one of -if not THE- most expensive part of a TV aside from the main motherboard internally.
So the fact that they replace it as un-repairable makes sense to me, though I'd probably repurpose the TV for the bedroom for example and buy another (if I can).
Hope this helps!
PS: Thanks for including the English version, since this is the English community ^^
- JD
TiberiuH
Hi
Thank you for reply
I cannot argue that the lcd is the most expensive part
But without any check from a specialist how to make difference between bad luck an the fact that the panel had a hidden defect from the factory which appeared after 2.5 years
If hidden defect Sony must repair during the lifetime of the tv which is 3 years as per Sony warranty paper (as per Romania law)
Regarding moving tv to another role the issue is that in 2 weeks the black line increased from 2 mm to 4 cm so I expect will continue to grow
Joe_Dohn
Specialist
I'm not sure about Romania law to be honest, but Sony offers a replacement instead of repair when there's an issue with a display due to a defect since it can't be repaired, but that is all up to an engineer who takes a look at pictures you send; so won't always necessarily mean a replacement is necessary.
That said, most of the issues I've seen when it comes to the display are usually pretty early on, usually within the first couple of months or so, but I'm by no means an expert so I can't say this for sure.
Hope this helps!
- JD
TiberiuH
Hi
As you stated the screen is the most expensive part of tv and if become defective tv must be replaced
So if your tv is out of warranty you must just purchase a new tv
This means as a customer I have zero protection if screen is broken
Due to this how can anybody assume the risk and purchase a very expensive high class tv if no protection
2-3 years is very small period of waranty even extended if you invest high amount of money in a tv
My view is that screen nust have higher warranty at least 5 years
As example for refrigerators an washing machines the invertor has 10 years warranty
If not all the risk is with customer and all the profit with the vendor
Joe_Dohn
Specialist
I can't say I disagree with your sentiment, but most warranties don't even cover the display with physical damage for example.
So if it's not defective, still within warranty, but let's say a child throws a toy at it, that means you're out of a TV.
This is essentially why insurance exists. Not that I like this fact, but it's just how things seem to work these days.
- JD
profile.country.IE.title
Noir07
Hi, can I ask how much do they charge to exchange the TV for you? Thank you.
