Satelite Tuning on Sony XG95 (Android TV)
samuelsmith
Hi all,
I have Sky (UK) but recently bought the XG95 so I could receive the free to air satellite channels and get rid of Sky.
I currently have Sky Q (Zone 1 Dish, Universal LNB) which is working fine.
I took the cable out of the Sky Q box & plugged in into the main sat connection on the TV.
If you do the simple full tune I get about 4 channels e.g. Bloomberg, etc - but I can't seem to figure out how to get any others.
I've tried going to https://www.lyngsat.com/Astra-2E.html to get the individual freq/polarity/symbol rates but still not finding anything.
Am I doing something obviously wrong?!
Many thanks,
Samuel
4 REPLIES 4
LightFoot
Specialist
Hi @samuelsmith
Sky Q uses a wideband LNB. Are you using a Hybrid LNB with six outputs? Sky usually replace the standard LNB with one only suitable for Sky Q.
samuelsmith
Thanks @LightFoot - I should have said I have a single cable universal Dcss LNB. In the settings I input fixed antenna with single cable.  So hoped that would have worked...
Like this one:
https://m.ebay.ie/itm/143208130076?ul_ref=https%3A%2F%2Frover.ebay.com%2Frover%2F1%2F5282-53468-1925...
Mick_D
Moderator
Hi @samuelsmith
Have you looked into going the Firestick/Chromecast/AppleTV route?
Mick
samuelsmith
Hi all,
So I bought the new LNB, changed it over and then re ran the full scan tuning on the TV.
This time it's a little better - It picks up approx. 230 channels (although most are duplicates).  However it seems like only half the channels shown actually work.
e.g. these are the ones that do work:
Channels
Freq
Polarity
Symbol Rate
Travel, DMAX, Quest, Food
12382
H
27500
Astra Promo
12441
V
29500
SkyNews Arabia, Pick
12148
H
27500
Channel 4, Film 4, E4
10714
H
22000
10936
V
22000
Which means channels like BBC 1/2/4/News, ITV 1/2/Be, Channel 5/5Spike/5Star, Challenge, Bloomberg, etc don't work.
One thing I notice on https://www.lyngsat.com/Astra-2E-2F-2G.html is that the ones listed under Sky seem to work, but the ones listed under Freesat don't seem to work.
Does anyone know what I need to do to get these working?!
Many thanks,
Samuel
