sloy response
costakouppas
Entdecker
sloy response
hi, ive just got a kd65xe9305 and the response on the tv from the remote no matter what i do is vert very slow on everything, the tv done an auto update when i first used it so firmware is upto date
1 ANTWORT 1
cass_n
Community Team
Hi @costakouppas,
Can you please try rebooting your TV and see if that fixes the issue?  If this doesn't work, the next step would be to try a factory reset.
Cheers,
Cass
