Sony 3D problem
mkj1972
Sony 3D problem
Hello everybody
I'm new to all this so please bear with me!
I have recently bought a Sony kd55s8005c tv & I have plugged all my accessories ps4 & 3D blu ray player into it using HDMI cables
However I switched on my 3D blu Ray player & the signal come on the screen 3D signal detected,I switched my TDG-BR1003d glasses on but the screen was still blurry
I don't think it is a problem with glasses because they worked with my old 37" Sony 3D tv
any help would be much appreciated
Thanks Mark
13 REPLIES 13
ZombieFried777
Yes it seems to be working now, I just turned the Bluetooth off and on again and it started working again.
I also bought Sony kd55s8005c TV recently and 4 prs of Excelvan G05-BT 3D glasses but can't get them to pair with bluetooth. Tried turning TV bluetooth off and back on but no luck. Any help greatfully received.
Hi @alfergu9854
Sony only officially support their own brand of 3D glasses.  You would need the TDG-BT500A 3D glasses instead im afraid.
sam2007
My TV is KDL-43W950C. After last upgrade V3.925, I cannot switch to 3D option from Action Menu. When changing to Side by Side nothing except only lot of vertical lines are visible. Even turning off the 3D option is not possible then. I'm using the Sony recommended TDG BT-500A 3D glasses.
This is getting very frustrating. Sony need to take these issues urgently for early resolution.
