Sony Bravia 43X75WL no record option
got2avekayanow
Hi all, hope someone can help with this it's driving me potty. I have the above tv new last week. I've registered 4 different HDD's with it for recording (only one at any time also de regitering so that only one at a time is registered) All were accepted as compatible by the tv. I've plugged them into the blue USB 3 socket (the inside one as instructed by the manual) I've registered my google account and signed up for youview but on the epg I am getting no option to record. I select the programme I want and all it offers is reminder (a bell appears on that programme in the epg) I understand that I can only record on the channel I am watching but that didn't bother me because I only really set to record when I'm out. What am I doing wrong ? I know this must be something I'm missing because it's not failed recordings, I just don't get offered the option to record when I select a programme as per the manual instructions. Is there something I haven't accepted or something. It's a good tv (not great) but I specifically bought it for the record option which other companies (Samsung) don't offer at this sort of price point.
Anyone know what I'm doing wrong ?
daveyh64
you have to come out of YouView and switch to Sonys own TV guide.
I have a different TV to yours so these instructions may not be exactly what you see but should be similar.
Click the Settings button your remote control.
From the onscreen menu select Settings.
Select Channel & Broadcast, scroll down to TV button shortcut.
Click right and select Digital.on the next screen 'Se;lect your default TV app for Digital' select TV.
(Live TV & Catchup is YouView)
Come to of Settings.
Press the TV button on your remote.
Press the guide button on the remote.
The TV guide you should now see is Sonys TV guide.
Select a programme you would like to record, highlight it press the OK/ confirm button on your remote
the next screen will show you details of the programme and the option to Timer Rec, click on that to set up the recording.
5 REPLIES 5
daveyh64
got2avekayanow
Great, thanks. You've restored my sanity. Not a mention of this in the manual (that I saw) I had assumed that you had to use youview (and I really didn't want to give up my info yet again to another organisation) Still I assume I can sign out of you view now.
Thanks for the assist. It's appreciated.
LightFoot
Specialist
Hi @got2avekayanow   There is no need to sign out of Live TV & Catch Up, just change the default TV App to (Sony) TV. Shown above.
got2avekayanow
It's not about "need" it's about desire. I only signed in to these things because I thought I had to for recording. Now I know I don't need to be signed in to them I choose not to.
LightFoot
Specialist
Hi @got2avekayanow   Do the iPlayers still work?
