Sony Bravia 4K Android intermittent reboot
Hamsterhead
Good Afternoon
Since the last software upgrade of a few days ago my Sony Bravia does a reboot (dancing yellow dot) when first switched on and intermittently throughout the day.
Is this a known problems?
Piscie
Community Team
What's your TV model? Also, try to unplug the TV from the power and then replug it back after 2 mins and check again it might helps.
Piscie
Community Team
Hamsterhead
I have done what you suggested and so far so good. Thank you
