XBR-65X900E Schematics
profile.country.EE.title
atom_sk
Hello,
Is there a way to find schematics For Sony TV XBR-65-X900E ?
5 REPLIES 5
Piscie
Community Team
You can check this PDF manual it might helps: https://www.sony.com/electronics/support/res/manuals/4457/4457217EM.pdf
atom_sk
Thank you so much for the help but these manual won't help. I a stuck at the step where I need to measure VDD on mainboard but I am not able locate C506 VDD voluted test point. These is why I need full schematics of the main board.
Thank you,
Pavel
Joe_Dohn
Specialist
I very highly doubt you could find that considering this is probably info kept private and only for engineers.
That said, you can try reaching out to the engineers in case what you're trying to do is something they can share/confirm?
Hope this helps!
- JD
atom_sk
Thank you!
I was trying to contact couple authrorized service center is the can help as they should have those otherwise how they can inspect repair those. But so far no luck ...
What I have found so far most likely these is the SW chip on the mainboard. I have check the power board it is fully functional main board received main power so need to replace mainboard.
Joe_Dohn
Specialist
I can see that the model you have is the USA/Canada one, and I'm not sure if that also tells me your region or if you're using it in the UK.
That said, If you are in the US/Canada, I'd reach out to the Sony support reps since they can give you more information about the service centres over there (I don't know much about them sadly 🙁).
If you're in the UK/Ireland, you can use the UK and Ireland service centre locator tools by Sony, they're pretty handy so I keep'em bookmarked! 😁
Hope this helps!
- JD
