Sony Bravia beep noise blemished Skewed
desmo999s
when turn on my Sony Bravia KDL50w755c the beep sound is blemished skewed crackling. Only beep sound. the sound of any channel are ok. I restart my tv and it is all ok
Hi there
Glad all is ok now.  If the beep does annoy you, you can turn it off in the settings > sound > system sounds
