annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Sony Bravia KD49XF9005BU
RÉSOLU
webb01
Explorateur
Hi all new here still looking about, anyway had my sony bravia KD49XF9005BU since April 2019 with no problems, then last night i was watching a film in zoom mode accessed from my remote (RMF-TX310E) via the Action menu, half way through film remote just stopped responding and now i'm stuck in zoom and can't find a way to turn it back to full mode, which is what i normally had it in.
TV seems to be working normally but can't access action menu from the three buttons on back of tv ?, normally watch tv through a freeview box, so can use temperly to turn program over volume extra, but still stuck in zoom annoying.
I ran through the remote control troubleshooter here and can see the ir light on phone, and the speech button seems to work, but can select anything ?, lastly tv still under warranty would that include the remote there £30 ish to last another year? ........ if i could just get out of zoom for now any ideas anyone cheers
1 SOLUTION APPROUVÉE
Solutions approuvées
webb01
Explorateur
Ps got free remote control under my warranty just for asking
Voir la solution dans l'envoi d'origine
3 RÉPONSES 3
LightFoot
Spécialiste
Hi @webb01
On your phone or tablet install the official “Android TV” App by Google LLC. Once paired press Home, Go to Settings, Display and correct your aspect ratio.
Sorry, forgot to say your Remote is covered in your warranty.
webb01
Explorateur
hey thanks this actually worked, i mean getting me of zoom, i downloaded the wrong apps a few times and a new learning curve to use the right one but i now got a new remote control on my phone that controls my tv, samsung galaxy s9 by the way for other readers in same situation ........ probably still buy a remote tho if i can't get from warranty thanks again
webb01
Explorateur
