Sony kd-55x9005c HD channels don’t look high quality.
Owp1000
Hi, I tuned the channels with my antenna cable plugged in. The HD channels just look like normal, why is this?
romeo_kii
hiya, thats because the tv is 4k loll, and the hd channels are probably 1080p/1080i or lower, leave sharpness at 50 , turn on reality creation auto  , random noise reduction low , digital noise reduction auto ,go into home, display settings and change display area to full pixel , helps on mine loll
