Sony tv adapter broken.
janzleri
So my tv adapter broke yesterday. Just asking if you guys have ever had the same problem and did the tv work after buying new adapter.
LightFoot
Specialist
Hi @janzleri   What type of adapter?
janzleri
19,5 V TV adapter.
LightFoot
Specialist
@janzleri wrote:
19,5 V TV adapter.
Hi @janzleri   It always helps if you could let us know the full model number of your TV. What exactly do you mean by broken, have you damaged it or is it simply not working. What have you tried, checked the fuse, tested the output just in case the power board has blown etc.? If the power adapter is still within warranty then Sony will replace it free of charge.
