Sony KD-65A1 TV and Sonos Arc
Simon23
Until recently my Sony KD-65A1 TV and Sonos Arc have worked perfectly since I purchased the Arc over 12 months ago. The Sonos Arc is connected to the TV via HDMI/ARC. Recently the TV sound on the Arc has been dropping out after using one of the TV Android Apps such as YouTube. Even when I close the App and go back to TV there is no sound. Once the sound has dropped out the only way to get the TV sound back on the Arc is to disconnect the power or HDMI so the sound switches to the in-built TV speakers and then reconnect the Arc when the sound is then redirected back through the Arc. I have tried all combinations of settings to try and resolve the problem without success. The Sonos App does not show the type of signal from the TV when there is no sound (blank instead of the usual Dolby Digital 2.0, Stereo PCM, etc.) so I think the Arc has stopped processing the sound from the TV HDMI. Both TV and Arc have latest software and I wonder if the issue is as a result of a recent software update? Any advice would be much appreciated.
Tags (2)
Simon23
GuitarSuperstar on the Sonos Community suggested the following and so far I have experienced no further problems.
Try this:
Disconnect everything from the TV including the Arc. Unplug the TV and Arc from power for a couple of minutes. Plug the TV and Arc back in but keep everything disconnected. Make sure Bravia Sync (CEC) is enabled on your TV. Run TV Setup under the Arc’s settings in the Sonos app and follow the instructions. When the app instructs you, connect the Arc to the TV’s HDMI ARC port using the Sonos-supplied HDMI cable. When the Arc has been successfully connected, connect any other device to the TV.
6 REPLIES 6
Marino.Manolo
Genius
Have you even just tried restarting Android TV?
Keeping pressed Power/OFF on the Remote...
Simon23
Thanks for your suggestion. I have already tried restarting Android TV and this will restore the sound but it will then drop out again after an Android App is used. It's quicker to pull out the power cord from the Sonos Arc.
khallergard
If you are using both HDMI and optical cable, try not using the optical?
Simon23
Not using optical, only HDMI. Has worked with HDMI for over a year, no problems until recently.
Marino.Manolo
Genius
The cause could therefore be a recent update that requires a factory reset or an update (a version) of one of your Applications ...
Simon23
Try this:
