Sony KD-75XH9005 issues
Greekevangelist
Bought this TV last week. Not impressed. Keeps crashing & rebooting by itself. Also, the 4K content is not as clear as it should be. Not getting that true life motion I saw when I bought the Samsung 75Q70 TV. I tried resetting once, but getting fed up with this Android software and sorely tempted to return this and buy a higher model Samsung such as the Q90. Any advice to improve quality of tv and this constant rebooting issue? No software update available.
Win_88
Specialist
Hi @Greekevangelist
When it comes to the motion clarity, make sure to enable MotionFlow: https://helpguide.sony.net/tv/haep2/v1/en/01-03-09_01.html
it will also help us help you if you let us know if the TV crashes randomly or while using a specific feature, Also, does it crash when no external devices are connected?
Win_88
Win_88
Specialist
Hi @Greekevangelist
Win_88
Greekevangelist
Thanks for replying. Turned on these settings. Not as real life as on Samsung Q70. Coshes when I was trying to use airplay. glitchy.
