Sony Kdl43W805c Freeze after turning on !
FlashMehiar
Hello !
i bought a KDL43w805c one month ago , and now i am facing a freezing problem after turning on the tv since 2 weeks ! , i have only an HDMI cable connected to the TV nothing els , this is my computer connectied to it , after i turne the TV off and turn it on all the time the TV freez i can see the Picture but NO sound and no Response from the Remote .
please some help ,
thanks in advanced !
4 REPLIES 4
Pocketacer
Hi, few of us have this problem, until there is a fix you have to either download the remote app and turn it off and on via the app or pull the plug on tv for a minute or so
FlashMehiar
a lot of thanks Pocketacer !
fist of all i would like to know where should i donwload the Remote app i did not understood , is it on the Tv it self ?
Pocketacer
No not on the tv, download it to your phone or tablet
FlashMehiar
yes i will try it thanks a lot and is there anyway that i can always keep up to date with this issue ?
