Sony remote to control sky
TraceyB1710
Hi I've just purchased Sony K D
LightFoot
Specialist
Hi @TraceyB1710   We should be able to help you but we need a lot more detail. What is the full model number of your TV. There is two versions of Sky boxes, Sky+HD or Sky Q. I assume that you are trying to set up the IR Blaster in which case only the Sky+HD works.
