Sony XF90 Channel Notification
Gulioth
Just started receiving a 'No channels stored" message (related to analogue tuning) on every startup which is starting to get very annoying!
Unsure why this had just started to occur - any ideas how to prevent from coming up?
Tags (3)
15 REPLIES 15
rooobb
WHy did you tune analogue channel if they are no longer existing anymore anywhere? just retune and avoid tuning analogue channel
Gulioth
I haven't (knowingly) tuned any analogue channel since digital switchover!
I've done the re-tune option which has had no effect.
rooobb
I didn't do the retune since a lot of time, but it should ask if you want to tune digital or analogue or both. You should also have on the remote a button for switching between analogue and digital in any case
Gulioth
Believe I've found the issue related to a Bravia Sync option that has recently been enabled but unsure a) how that would be related and b) if just coincidence!
Gulioth
Still receiving these even after a factory reset...any ideas?
rooobb
Which device have you connected to the tv?
Gulioth
No set top box just a Xbox 360 and Nintendo Switch.
I'll share a screen grab later.
Win_88
Specialist
Hi
Could you show us that error message?
Win_88
Gulioth
Sorry yes will send in a bit.  Noticed a software update applied today so be interested to see if it resolves or not (hopeful thinking!) .
I am completely stumped what could be causing it - my physical setup hasn't altered since I've had the TV (that I can think of) and have since tried changing any relevant setting that I can find to no avail.
