Sound bar (HT-SF200 2.1) obscures TV sensor on KD-49XF7093. Can I get higher legs for TV?
jabriall
LightFoot
Specialist
Hi @jabriall
You need to enable the IR repeater function on your sound bar. Have a look at page 17 of your manual.
https://www.sony.co.uk/electronics/support/res/manuals/4727/47274142M.pdf
LightFoot
Specialist
Hi @jabriall
jabriall
Thanks very much.  It works without problems.  I wouldn't have located that page of the manual if you hadn't pointed me at it.  It's simple when you know how,
Thanks again.
