USB stick
jonjo1945
USB stick
I used a USB stick to watch some films and all worked OK. The stick was removed when finished with but the menu has remained on the TV. Every time I put a stick in the original menu still comes up. Any suggestions how to remove the menu please
Sean_Mc
Moderator
Hi Jonjo,
Welcome to the community.
Can you tell us your TV model number and the type of USB stick you were using so that we can look into this for you?
Thanks,
Ed
jonjo1945
Hi There. My son informs me that it wasnt a USB stick but instead it was a solid state 1TB external hard drive. The TV model number is KD55XD8599.
Hope this information helps.
John
Sean_Mc
Moderator
Hi John,
Thanks for getting back to us. There are some guidelines and troubleshooting tips for using an external hdd with your TV here. Hopefully this will help with your issue.
Best wishes,
Ed
