Wall Mounting KD43 XE8005
AndyCr15
I have a generic wall mount, screwed into my wall already, so I'm looking to mount my soon to be delivered Sony Bravia to it.  A few things I've google'd suggest it wont be as simple as with my Samsung... What will I need to be able to do this?
Thanks!
6 REPLIES 6
IamNic
Hi @AndyCr15,
if your mount allows adjustment of the TV-mounted side to fit the holes on the back of your TV, I see no reason, why it should be more difficult to mount it to your wall-mount than your old TV.
- Nic
AndyCr15
Okay, thanks.  It has two bars that have a variety of wholes that can be any width apart that I need, as long as the TV has a fairly flat back with the four wholes, I should be okay then?
Will the screws come with the TV?  Samsung didn't include them and I had to order them online.
IamNic
Hello @AndyCr15,
that sounds good to me.
Not as far as I am concerned, yet it is possible, that the screws you used with your previous TV fit on the Sony as well.
- Nic
AndyCr15
Do you happen to know what screws would be needed?   (Or where I can look it up?)
Thanks for the help.
IamNic
Hi @AndyCr15,
I sadly don't know the thread size on the back of the TV.
- Nic
AndyCr15
Okay, thanks for your help.
