Which wireless sub for KD-55XD9305
Geekyhawkes
So I'm trying to find a wireless sub for my KD-55 but the only Sony subs I can see are the old SWF-BR100 and they seem to be out of stock everywhere. Can someone recommend a sony wireless sub for my KD-55 that's still available?
Thanks;
Andy
Hi there
Only the SWF-BR100 is compatible with your TV.  Others subs will not work, due to the fact that the TV does not have a standard sub-out port.  The SWF-BR100 comes with a USB wireless transmitter that plugs into the TV and hence the drivers have already been pre-built into the Android OS.  You cannot use other wireless transmitters to do the same job unfortunately.
In regards to where you can purchase the SWF-BR100, have you tried E-Bay?  Alternatively, you could purchase a 2.1 Soundbar system?
