X8500D and KODI consumption of RAM
BNDRJH
Hello everyone
I'm having problem with KODI
It consumes too much RAM
is there any way to expand that RAM ?????????
profile.country.HR.title
kinggo01
RAM? Or storage?
I've never noticed RAM issues with KODI. And no, you can't add more RAM.
Storage on the other hand can be expanded on MM but it's not reliable in the moment. And storage in KODI can grow..... a lot. It depends how large is your library and how many thumbnails you have. And also, how many add.ons you have.
BNDRJH
Thanks kinggo01 for your valuable answer.
could you please give me more details about KODI and the best way to maintain smoothness.
and how to add more memrory capacity to keep KODI run smoothly.
kinggo01
KODI runs smooth as is, at least the official version without all those piracy add-ons. Adding storage (just format a disk as internal, but that is broken ATM so don't) won't help with smoothness, it will just help with storing all those artworks and what not. You can always go to settings-apps-downloaded-find kodi and see how much storage it consumes.
