XE9005 and shadows pumping on hdr
Vplaas
Most of the time hdr is fine but sometimes when watching Netflix or iTunes shadows start to pump annoingly. It happens often with shady Marvel series. It does not occur in bright scenes.
Is there a way reduce this? I switched hdmi port and tried tons of settings. Subtitles seem to be making it worse. I had to reduce them to 50 % opacity.
Games on PS4 and Xbox One X seem to be fine.
Tags (3)
Hi there,
Have you updated to the latest firmware?
Best wishes,
M
stormyuk
Can you explain what you mean by pumping? I have no issues on Amazon Prime Video HDR or BBC iPlayer HDR content. I also have a PS4 Pro which is fine.
I have Netflix but I don't have the HDR/UHD subscription at the moment but will probably upgrade to this when my free trial isup.
Cheers.
