XH80 Seires
Lemax20
XH80 Seires
Hi All, Just had an update to PKG6.5076.0635 does anyone knows what bugs it fixes?
HannahEd01
Community Team
Hi Lemax20, it resolves an issue where there was no picture and/or sound when switching to Terrestrial input.
5 REPLIES 5
rooobb
Bydandie
It has a security update from Jul 21.  Installed over USB which was a palava as it needed to be on a 4Gb USB drive via Windows (macOS extracts the ZIP file).
HannahEd01
Community Team
Lemax20
Thanks!
HannahEd01
Community Team
Do you have a certain issue that you're after a resolution for?
