Dear Sir,
Can we increase battery upto 3000mAh by replacing new battery ?
As Battery does not giving good backup while using Power Management.
So can you develop new battery with increase battery mAh from 2300 mAh - 3000 mAh for better performance.
Give any suggetion on this.
I am waiting for your reply.
Solved! Go to Solution.
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Thank you for the feedback. I will forward this internally.
my xperia c is around 8-9 months old . I'm Having a problem that from couple of days when im charging my phone it get's charged upto 40-60% then suddenly the charging stop's nd when i connect other phone to they charger then don't get charged
I have Bought almost 3 chargers nd all of them have been burned from inside nd not only charger some time's the cable also dont work is it a problem of my phone or the usb connector built in the phone
