Solved! Go to Solution.
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Does the menu button work on your headset? Have you installed the application "Stereo Bluetooth Headset SBH50":
https://play.google.com/store/apps/details?id=com.sonymobile.smartconnect.collins
Which music player are you using? Have you tried to connect the headset to another phone to see if the buttons work?
