select copy and paste
cris2015
Hello! How i can to select, copy and paste a text from a web page. Regards. Cris
Phy
Legend
Legend
Yes, long press on the text and you should get a tool bar at the top. Select the double pages icon. Then go to where you want to past the text and long press again and a past option should appear.
6 REPLIES 6
Phy
Legend
Legend
Phy
Legend
Legend
And to select the text just move the arrow that appear when you long press on the text. However, if this doesn't help can you elaborate more on what exactly you are trying to do.
cris2015
Thank You ver mucho..... I copy and paste this:Yes, long press on the text and you should get a tool bar at the top. Select the double pages icon. Then go to where you want to past the text and long press again and a past option should appear.
cris2015
Thank You
Phy
Legend
Legend
Ok. Glad it worked for you.
Thommo
Genius
@cris2015How is your answer correct when Phy told you what to do and how to do it
