The message you are trying to access is permanently deleted.
Iam using xperia C3 dual.Whenever i press home button and then go to recent apps and select an app for eg. Facebook or whats app it does not resume where i left the app is getting restarted from the begining,why is it so? Is 1gb Ram is insufficient for background tasking? Iam even losing game if some call comes in between, please help me with this problem....
Solved! Go to Solution.
If you are using heavy apps and have a lot of background apps, Android will free up RAM as needed.
Do you have any antivirus or taskillers? when you exit an app do you press back or home?
