Since downloading and installing the software update, there is a gray toolbar across the top of the window blasnking out icons. There are two buttons, one a settings and other + to add plugins, both do nothing, any ideas?? Also it cannot be deleted.
Message was edited by: bladerider958
Hello bladerider958 - Welcome to the Sony Forums
That does sound a little bit strange. Would it be possible for you to take a photo of the screen with the grey bar and then upload it to this forum discussion so that I can look into this further for you (I can also do some further research to see if this is a known issue).
If you get any trouble when trying to attach photos here, let me know and I can provide you with an alternative.
Thanks,
Simon
Thanks for responding, here is a desktop snip
Any joy Simon??
David
Hi David – is it not possible to click on one of the main menu items ('Getting around', 'Drag & Drop', 'Easy Sharing')?
Mick
Hi Mick - I can use those buttons, but i dont know how to get trid of that defective toolbar.
David
Hello again
Thanks for the screen shot. I am going to try and get some further help with this issue and I will let you know if I can offer any advice about the grey bar.
Simon
Many thanks Simon
Hello again
I have had a reply from a Customer Support Representative and they have advised me that this is an isolated issue. If you upgrade to PlaymemoriesHome, this should work without any problems. If you let me know exactly which model of Bloggie that you have, I will provide you with a download link if you need it.
Thanks,
Simon
Hi Simon
Thanks for the update. My model is Bloggie 3D MHS-FS3
Regards
David
