Bloggie Software update
bladerider958
Since downloading and installing the software update, there is a gray toolbar across the top of the window blasnking out icons. There are two buttons, one a settings and other + to add plugins, both do nothing, any ideas?? Also it cannot be deleted.
Message was edited by: bladerider958
12 REPLIES 12
blaireau_photo
Hello again :slight_smile:
Are you able to install and use the version listed below?
http://support.d-imaging.sony.co.jp/www/disoft/int/download/playmemories-home/index.php
Thanks,
Simon
bladerider958
Simon
Downloaded, up and running.
Many thanks for your help
Regards
David
profile.country.nl_BE.title
guntherwuytens
I have a similar problem. I can't download and install the latest version of playmemories home. I have the lite version on my computer and cannot edit video's for example. If I try to download/install/upgrade, I always get a message that some PMB or PMH related program is already running, even if I close all programs and only start the download from the internet. See the screenshot hereabove.
I even tried to remove my old PMH completely, but a few files cannot be deleted (similar problem, some programs are running is the error message...)
Can you help me, or forward my problem to people who can help?
Gunther
Message was edited by: guntherwuytens
