Camcorder screen blank.
i005982
The screen on my HDR-TG3E is blank. Any ideas ?
Mick2011
HI, welcome to the Sony Forums :slight_smile:
It could be anything from a camera setting to a broken ribbon cable. Unfortunately it's very difficult to say without checking the camera.
You could try a reset (press the Reset button – see p.99 or the manual) and see if that helps. If not, it's most likely an internal fault. You could try a local electronics repair shop, camera store or check this sticky post for details of the Sony repair service.
Mick
