I have a DCR-PC9E camcorder. Are there any external microphones suitable for this model
Regards
ridleyn123
Solved! Go to Solution.
Hello ridleyn123
I have taken a look at the manual for your camcorder, and it seems that there is a standard microphone socket that you can use (page 121):
http://pdf.crse.com/manuals/3068332121.pdf
As long as any particular microphone has a 3.5mm jack on the end, it should be compatible with this camcorder. There is a pretty large selection available from sites such as Amazon or eBay, and a search for '3.5mm microphone' will show you that there are a number of choices available for around £10-£15.
Thanks,
Simon
Hello ridleyn123
Thanks,
Simon
