DCR-TRV145E
profile.country.sk_SK.title
high182
DCR-TRV145E
Hi, I have dcr-trv145E and notebook with win7. I need drivers for this product. I have connect dv to usb.
blaireau_photo
Hello high182 - welcome to the Sony Forums :slight_smile:
The most up to date drivers for your camera are available here:
http://www.sony.co.uk/support/en/product/DCR-TRV145E/downloads/usbdrven
However, there is no 'official' compatibility with Windows 7. This doesn't mean that your camera will not work though - you may need to purchase a Firewire adapter for your laptop such as this one:
http://www.amazon.co.uk/PCMCIA-Firewire-IEEE1394-Laptop-Expansion/dp/B000OQA8AC
You may find it easier to get a USB/Firewire adapter - there is a range of them available on Amazon:
http://www.amazon.co.uk/s/?ie=UTF8&keywords=firewire+to+usb+adaptor&tag=googhydr-21&index=aps&hvadid...
You may also find that you get good results by using Windows Live Movie Maker 2011. It is free software that may already be installed as part of your Windows 7 setup but if you don not have it yet, it can be found here.
Thanks,
Simon
high182
Thank you Simon for your ideas, but it doesn't solve my problems. I have notebook HP G62 and I need connect camcoder Sony DCR-TRV 145 e. I have wire usb/dv and Win7. Anything else ideas? My english is not very good, I am from slovakia and I learning english only 6 month.
blaireau_photo
Hello again :slight_smile:
Other than installing a Firewire adapter on your PC, it may be worth considering installing Windows XP on a seperate partition on your hard drive (this can be done if you have a copy of the CD and a valid licence key from a previous machine). You can store the imported video files in a folder that is accessible from both operating systems.
Thanks,
Simon
