Drivers wanted for Handycam HELP!
sinclair147
Hi, can anyone help me with my driver problem? I have a DCR HC-18E handycam but my operating system (vista 64bit ultimate) wont let it run? How/where do I get drivers for this problem?
thank you,
Karl
Thalamus.
Champion
Hi Karl,
If you PC/Laptop has a FireWire port it should look something like the image below..
and may have one of the symbols below
5 REPLIES 5
Thalamus.
Champion
Hi Karl,
welcome to Questions & Answers..:smileyhappy:
It seems the original drivers & software are not Vista or windows 7 compatible..
Does your PC have a firewire (iLink) port, if so try connecting your HC-18 to your PC using that port.?
sinclair147
Hi Thalamus and thanks for taking time to answer me:smileyhappy:without sounding thick as a plank "whats a firewire port and where would I find it"?
thanks:smileyconfused:
Thalamus.
Champion
Hi Karl,
sinclair147
Hello Thalamus,
yes I have a six pin port on my pc. where would I get a cabble for it and will it work?
thanks
Karl:smileyhappy:
ps. What does "correct answer" and "helpfull answer" mean? and do I need to tick them after a reply?
Message was edited by: sinclair147
Thalamus.
Champion
Hi Sinclair147,
you should be able to purchase a FireWire cable from Maplins or similar local pc/electronics store..
Correct Answer &/or Helpful can be selected when,..
A. When you consider a users reply has been helpful in solving your original question..
B. If a reply has solved your problem then you can select Correct Answer so that the solution can be easily identified by others with a similar problem..
