E:91:01
profile.country.no_NO.title
isakmenes
E:91:01
What does the error code E:91:01 indicate on my Handycam PJ30VE?
Tags (4)
Mick2011
Hi isakmenes, welcome to the Sony Forums :slight_smile:
That error normally relates to the flashlight function. It can sometimes be dealt with by resetting the camera, instructions for which should be in your user manual.
Using a pointed tool such as a ballpoint pen, press the small reset button on the side of the camera for 2 seconds.
Hopefully that will clear the error message; if not, you may have to look at a repair. Let us know how you get on.
Mick
Mick2011
Mick
