HDR-CX190E - Viewing image saved onto external hard drive
magwynn22
I have recently purchased the above camcorder - which I am very happy with.
I can transfer files onto my computer, view and edit accordingly.  I can also view files when I plug the camcorder directly into my TV via HDMI cable.
However, when I transfer the files onto an external USB hard drive, I cannot play the files on my HD TV via the USB port.  The files are definitely on the device, as I can still access them and view when I plug the hard drive back into my computer.
I suspect it is something to do with the file type, but I wondered if anyone out there has a a similar issue and might be able to help me to access the files on my TV.
Matt
Message was edited by: -Soup-
Personal details removed
16 REPLIES 16
magwynn22
I have converted the files using the Sony Playmemories software, and I still have the same issue of no sound.
I tried Windows Movies, as this was also pre-installed on my laptop.  This produced the same result.  Images are there, but no audio.  Also, it takes an incredibly long time to convert using this program.
Finally, I tried downloading a sample version of Wondershare Video Converter.  This is a really easy piece of software to use, and I managed to convert all of my AVCHD files into mpeg2, which then play perfectly on my TV - including audio.  The only catch is that a watermark is displayed across all images, as the files have been created using the sample version.  The full version if $69,95.
I didn't really want to part with this money, as I haven't budgeted for it.  One of the reasons I purchased the HDR CX190E is that I could save / store onto hard drive, then play on my HD TV.
Do you know if there is any other free software that I could use to get the same results?  Or should I be able to do this using the Playmemories software?  When in PlayMemories, I am simply using the 'convert' function, and saving directly to the 'E' drive.  Is this the correct method?
Mick2011
You should be able to choose Mpeg-2 as an output option in the Manipulate > Convert menu:
Mpeg-2 is certainly the most likely to work and there's probably nothing special about the Wondershare conversion, other than perhaps being a little faster. Sometimes free apps do the job just as well as paid ones, sometimes not... but I'd be surprised if the PM conversion to Mpeg-2 didn't work.
Let me know how you get on.
Mick
magwynn22
Hi Mick
Now I'm totally confused.  The AVCHD files that I have been trying to convert now play on Playmemories with no audio, and the Playmemories doesn't recognise my external device - so I cannot convert and export to it.
However I still have no problems playing the orignal AVCHD files in Windows Media Player - with audio.
I suspect that Playmemories is getting confused between old versions of the files that I have registered to view, and the new versions.
I am tempted to uninstall Playmemories and start from scratch.  Would you recommend this course of action?
magwynn22
Hi Mick
A final update for you.
I have uninstalled and re-installed Playmemories.
I registered my AVCHD files for viewing.  I can view them within Playmemories, including audio.
I have then converted the files to mpeg, and saved to my E drive.
When I then go to view the files on my E drive using the USB port on my HD TV, the files play, but again with no audio.
I then tried convering the original AVCHD files using the trial version of Wondershare.  This converted the files without a problem, which I then played successfuly on my HD TV using the USB cable - including the audio.
I conclude that there must be something in the way that Playmemories converts the files that renders them incompatible with my HD TV.  Therefore if looks like I will be parting with $69.99 for the full version of Wondershare - unlss anyone out there knows of another free file conversion program, or an upgrade to Playmemories that will cure this problem.
Thanks for everyones comments and assistance.
Matt
magwynn22
Further observations......
I have been checking the properties of the converted files.
When you convert AVCHD files in Wondershare, it converts the audio files to Mpeg format.  When you convert in Playmemories, the audio files remain in Dolby Digital format.  I suspect this is where the problem lies, and Playmemories is not going to allow me to convert files compatible with my HD TV.
It doesn't look like Sony Playmemories is up to the job....!
Matt
blaireau_photo
Hello again :slight_smile:
Am I right in assuming that the original files are in M2TS format?
If so, if you type 'Free M2TS to MPEG' or 'Free M2TS to AVI' into Google, you will see a few options that claim to be completely free alternatives to paid software. It may be worthwhile to try a few out. In the past, I have used this one with some success:
http://www.m2tsconverter.org/
Thanks,
Simon
magwynn22
Thanks - I will give that software a go.  When I use the free version of Wondershare, it leaves a watermark across the screen for the converted files (obviously to encourage you to upgrade to the full version).  Does this free software also have a watermark, and are there any limitations on use?
