Hi, I have finally updated my computer but I cannot find my PMB disc for my DCR-SX30E. Can anyone point me in the right direction of a downloadable version? I have looked on the Sony site but I can only find updates...
Solved! Go to Solution.
PMB is not supported anymore, and it’s difficult find a Sony’s site download.
For quite all Sony’s Camcorders now, is using Play Memories Home.
Here’s the link of your Camcorder: Sony support DCR-SX30E
Even if is an update, you can download and install it. Then probably you have to connect your camcorder to install or activate it.
| Non mi aspetto nulla. Non temo nulla. Sono libero. - I hope for nothing. I fear nothing. I am free. (N.K.) |
Thanks jan2011. Worked exactly as described below.
You're welcome!!!
