PMB not recognising external drive
battyhouse
I want to save some files which I downloaded to PMB and then save to an external drive, however when I try to export the files, PMB does not pick up the drive even tho my computer does.  How can I get PMB to recognise the drive?
blaireau_photo
Hello :slight_smile:
You may have already tried this but have you updated to the latest version of PMB. It may seem like a 'standard response' to your question but I have seen a few similar PMB questions lately where the latest version has fixed an issue. The latest version for your particular camera is downloadable from the support section of the Sony website:
http://support.sony-europe.com/index.aspx?site=odw_en_GB
Thanks,
Simon
blaireau_photo
Thanks,
Simon
battyhouse
Hi Simon
Thanks for the info, I have just got a new desktop and just loaded PMB from the original disk, assuming it would look for updates!
Many Thanks
