I wondering how to shoot slow motion and super slow motion with RX0 II... For some reason RX0 II shoots only couple of seconds and stops. Tried several different setups, but same thing continues. Where there could be the problem?
Hi @J.Hanhinen,
as I do not possess that camera I can only draw your attention to the help manual. On this page it says (close to the bottom of the page) that the duration of a shot will be either 2 or 4 seconds, depending on the setting. That's most likely the reason for what you're observing.
darkframe
