Sony HDR CX-550VE Buffer overflow
profile.country.hu_HU.title
anagami
Hello, I also need your help concerning „buffer overflow” problem.
The camera was purchased in 2010 by my boss, who used it only for making HD HQ shots – without problem. Since two months we have used the camera for making SD shots and after about 40 minutes shooting the camera pops up the message BUFFER OVERFLOW in nearly every second and of course stops working. After a 5 minutes stop the camera is able to continue for ca. 15 minutes and then starts again with the popups.
There is no drop sensor in this camera as it has an internal memory and not  a  hard disk, so these cannot be the explanation. The strange is that shooting in HD mode the camera is working well. So we have the fault only in SD mode.
Is there a solution or an explanation for this problem? The Hungarian Sony service has not heard about this problem yet and they have no idea about the reason.
I am looking forward for you replies and help!!!!
Thanks!
8 REPLIES 8
blaireau_photo
Hello anagami - Welcome to the Sony Forums :slight_smile:
Is this error only occuring when recording to the internal memory or does it happen when you are trying to record onto an SD card or memory stick as well?
Thanks,
Simon
anagami
Hello Simon,
yes, unfortunately it happens also at recording onto an ("external") SD card.
Anikó
klauzser
Try using a different SD card. That works for me when I changed my SD card.
anagami
That we can try of course. Good to hear that this can help! :slight_smile:
Otherwise have you probably tried to find out the reason for the problem at a Sony service center?
Anikó
profile.country.ro_RO.title
galea2000
Hello
I have same problem to Sony HDR CX550 - 64 Gb internal., random - buffer overflow - , sometimes camcorder turns off while recording.Used internal memory. But  I don't loose the footages it's auto recovered.
I try: reset from small button, power off - nothing.
Place a card SD, card extreme video from SanDisk 30Mb/s class 10 - same error.
Format the memory from camera - same error.  If a leave the camera without battery for 1 hour - same error.
Can be rerwite the firmware? . I think is a software error.
Thanks.
profile.country.tr_TR.title
ilhamiyanik
Hdr 550 ve cameramı kullanmaya doyamadan aynı sıkıntıları bende yasadım
Cozum adınada yıne aynı yontemleri denedim fakat cozum olmadı
Teknık servis ise
Kameraların calısma mantıgında once birönbellek e (ara bellek) kayıt yaptıgını oradan da hafızaya aktardıgını, bu hatanın ise ön bellege gonderilen goruntunun normalınuzerınde olması yada diger bır tabirle on bellegın gelen goruntuyu karsılayamaması olarak tanımladı. İki sebebi olabilirmis
Ya anakart bozuk yada hard dısk
Her ıkısı de yenı bır kamera parasına takın...
Ben bu durumun fırmasan uretım hatası olarak yasandıgını dusunuyorum
-Soup-
Hi ihamiyanik,
Welcome to Sony Forum! This is an English language forum and it's preferred you post in English so other forum users can help you more easily. If you prefer the forum in Turkish you can find the link here:
http://www.sony.com.tr/discussions/community/tr/destek?lang=tr
Kind Regards,
-Soup-
Forum Moderator
profile.country.de_DE.title
cmosse
Found this on a Sony support site:
http://www.sony-asia.com/support/faq/441764
Q:
How to resolve when "Buffer overflow. Writing13:35 09.11.2012 to the media was not completed in time." message appears and the recording automatically stops?
A:
Recording on a memory card may fail if you repeat copying and deleting image files or text files on a memory card using the computer, or if you format the card using other devices. In this case, format the memory card using the camcorder. Be careful that all the data will be lost if you format the card.
If the performance of your memory card is low, recording data may not be written in the memory card and recording may stop with the Buffer overflow message. Check the usable memory card as follows;
SD Memory Card
- SD Memory Cards with Class 4 or faster
- SDHC Memory Cards with Class 4 or faster
- SDXC Memory Cards with Class 4 or faster
Memory Stick
- Memory Stick PRO Duo (Mark2)
- Memory Stick PRO-HG Duo
