Does Sony DSC-RX100M7 support plug-in power?
profile.country.NL.title
joaoSilverio
Hi there,
I have purchased a RØDE VideoMic GO II, which uses plug-in power, but I doubt if my Sony DSC-RX100M7 supports this and if it's compatible?
Does anyone of you have experience with this item?
Thanks,
Joao
Marino.Manolo
Genius
https://helpguide.sony.net/dsc/1920/v1/en/contents/TP0002392778.html
21.  (Microphone) jack
When an external microphone is connected, the built-in microphone turns off automatically. When the external microphone is a plugin-power type, the power of the microphone is supplied by the camera.
Marino.Manolo
Genius
joaoSilverio
Hi Marino,
Excellen, thank you for your great help!
Cheers,
Joao
