Full Manual for DSC-HX300
King5teve
Hi All. Is there a full manual available for the DSC-HX300? There is a 34 page paper pamphlet supplied with the camera and thae same is all I can find on the support website. Thanks.
jumpsuit
Hi King5teve and welcome to the Community :slight_smile:
Have you had a look Here?
There are 3 manuals available to download (I had a quick scan and don't think they're the same, but double check.)
jumpsuit
